Hello,
I am considering a new to me boat. I know just enough to be dangerous and did a compression test with a friend who knows a little more. The numbers have me confused. After searching a bit I think we made some mistakes that may or may not explain the numbers. It is a 1999 Mercruiser 7.4L MPI motor.
The engine was cold and the throttle was at idle(in the neutral position). The numbers are:
1: 90dry/90wet 2: 90dry/90wet
3: 120dry 4: 90dry/105wet
5: 100 6: 120
7: 90dry/110wet 8: 80dry/80wet
Can anyone explain what may or may notbe going on and/or whether the test is useless due to the procedure used? Service records show some previous overheating issues.
Thanks!
5: 100 6: 120
Thanks!
