akmoosehauler
Thread starter- Joined
- Aug 29, 2007
- 78
Took it out for the first time since getting it back from dealer.
Ran with the zuk 23 pitch prop as had a light load along with a lift on the motor.
Could only get 5600 to 5800 rpm full throttle. Barely to the 5800rpm.
That was even raising the motor till i had cavitation.
Will try the 21 pitch prop on next run to see where that goes.
With the lift on the anticav plate is 2inches above the bottom of the boat at full up position.
Also the only info i have from the dealer is that the motor checked out fine BUT only has 175psi on all cylinder for compression.
Will check all of them again and borrow some other gauges to compare.
Anybody have anything else that might help?
Thanks.
Thanks.
