30hp Johnson starts but
socgray
it will idle run at low rpms but it won't open up sometimes while at idle sounds like its running out of gas and as soon as you try to open it up die's:confused:also how do you figure out which carb this has if it needs to be rebuilt
jasper60103
Re: 30hp Johnson starts but
What year is your motor or post the model number? Also, what's the history? Is this a new to you motor?
jimdd810
It sounds as if you need to go throught the carb. If this motor has been sitting for a long time then look for the sticky about firing up a long dormant motor.
socgray
I was hoping the seafoam would help this 1986 30hp but all sign's point to the float in the carb is done
HighTrim
Is this a new motor to you? It may need some adjusting if so.
Start with the basics.....fuel, spark compression.
Daviet
Like HighTrim suggested, start with a compression and spark test, if every think checks out it is most likely a fuel problem.
Sea Foam will help keep your carb clean but will not clean it if it is dirty or has passages plugged.
Sounds like it might be time to remove the carb and overhaul it.
