Mercruiser Missing
keoni757
Well, it's not actually missing, I mean I know where it is. But it is missing while its running. The miss seems to only occur after about an hour or so on the water, then the engine begins to miss or "cut out" briefly, usually while under a load and at power settings above about 2000 - 3000 rpm. Once the missing starts, it seems to gradually get more frequent, to the point of actually stalling the engine. When it does stall, it starts right back up like nothing happened and runs for a bit and starts the whole process over again. My engine is an '03 mercruiser 260hp 5.0 liter MPI. It has about 100 hrs. on it. So far I have changed the cap and rotor, fuel filter and spark plugs (but not the wires). I'm thinking the problem may be electrical in nature due to the fact that it doesn't occur immediately, but only after the engine has been running for a while (about an hour to hour and a half). I have been told that my batteries (2- 550 cci's) are undersized and that might be a consideration. Any thoughts or suggestions would be greatly appreciated.
Brewman61
Ensign
Re: Mercruiser Missing
Could be electrical, but also consider it could be fuel related. Next time it starts to miss, try loosening the gas cap. If the tank vent isn't clear it's posslble that could affect fuel flow after the engine has run long enough.
That's probably a long shot, but cheap to eliminate, at least.
It's also possibly vapor lock- fuel vaporizing in the line somewhere.
Certainly could be electrical too- with many different possible causes.
kikroks
could be your ignition modual they are known to fail occaisionly when over heated electronics and heat are not good friends .it being an 03' your probably going to need to put it on a diagnostic computer. Im assuming its fuel injected . oh change your water fuel separator filter cant hurt.
keoni757
Thanks for the replies. I'm still not ruling out that the problem could be fuel related. However, I did change out my fuel/water seperator and it didn't appear to have any water in the fuel. I will definately try loosing the gas cap next time it happens, hopefully it doesn't happen again. If loosing the cap works, what would the fix be?
Fishermark
Cleaning out the vent / vent hose.
If the vent gets clogged (mud daubers, etc), a vacuum develops in the tank and the engine begins to starve for fuel.
