Passage through transom hole repair
bisonfan
Hello - I need help/ideas on a repair. The attached pictures are from a water passage through the transom on my boat. The plastic is good on the outside but not the inside. Wondering if anybody has run across plastic inserts or tubing or something that I can use to fix this?? I really don't want the transom to rot away!!
Thanks for your help!!!
sublauxation
Re: Passage through transom hole repair
Looks like just a standard drain tube, Sea Choice makes them in plastic available for about $4-$5 or less and sold by most on-line marine, check out iboats, jamestown distributors or greatlakesskipper
sublauxation
I sealed mine with 3m 5200 sealant, some may argue that the 4200 is better because it isn't permanent but I'll vouch for the 5200 working really well.
Woodonglass
they sell em right here on iboats. Transom Drain Tubes
