Gear part number change up???
Mercproject
Would anyone be able to tell me if the following part numbers are valid, or did they change up.
For a 1966, 650 Mercury, 4 Cyl, serial # 1869630
Forward gear - C-43-31886
Clutch Dog / Sliding Clutch Ratchet - C-52-34239
Reverse Gear - C-43-31887
Thanks
Andy K
Fun Times
Re: Gear part number change up???
Thanks
Andy K
FYI, This Information below is going by the part numbers you posted only, Because I did not look up the part numbers using your engine serial number.
31886 is Superseded to 53100A3, But it is No Longer Available. But if your mercruiser dealer is good, then using part number 53100A3, they should be able to find one for you through other mercruiser dealers throughout the country.;):)
34239 is Superseded to 822539T, And it is a Active part. $171.25
31887 is Active for now with parts in stock, But going to No Longer Available soon.;) $372.69
Type your part numbers in this link.;)
http://www.mercruiserparts.com/partsByNumber.asp
Hope this helps, Good luck.:)
Mercproject
Thanks for the quick reply, and info
Thanks for the info - I appreciate it.
Now just have to make some decisions
Andy K
