FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
1997 5.7 efi starts fine runs a little ruff but stalls when put in drive or reverse, the throttle was stuck now it moves foward and backwards but cuts the engine out in either direction
just read don s post...shouldnt shift on muffs..well the starboard shifts to foward and reverse with muffs and NO prop...port still stalls... so much for that theory
thanx for that info..does anyone have a pic or can tell me where its located..and also is this a simple part change or is it more complicated then that
usually on the stbd riser where the cables are. If the switch it activating ,it means the cable is bad. I think you mis-read the post. If it operates the switch on muffs while shifting, the lower cable is bad.
ok more info..just put both throttles in foward then tried to turn prop shafts.. starboard locks up port does not..put both in reverse starboard locks up and so does the port.. does this info help in any way?
