Michigan Vortex Vs Match
NHGuy
Michigan Wheel makes 2 21 pitch 3 blade aluminum props for my drive. One is a Vortex which I believe requires a hub. I have a 19" Vortex so I believe my hub will work. They also show a Michigan Match in 21". Can anyone tell me what difference to expect if I get one or the other?
Oldskool
Re: Michigan Vortex Vs Match
You should see similar results. The Vortex prop allows a dealer to stock a limited number of props, yet service a wide market by having different hub kits. Much more cost effective. The upside for the boat owner is that in the event that you need to wish to move up or down in pitch, or to a 4 blade from a 3 blade, you can puchase just the prop and use your same hub kit.
