3car
Thread starter- Joined
- Apr 2, 2006
- 132
motor will idle and Rev in a hose. in the water it will idle but it stalls when you put it in gear. here's a few details.
-1986 evinrude 140
-carbs rebuilt
-125 Psi compression on all 4 cyl
- new champion plugs
- timing set to 18 degrees per Reeves method
- new fuel filter and fresh gas
-seafoam decarb
- link Ans sync.
the timing was 8 degrees off, and I adjusted it to spec.
I got fed up and took it to a shop. the mechanic tells me that the timer base is bad, and its $240 plus labor. if the timer base was bad, would the motor run? would I have been able to adjust the timing? I want to make sure I'm not throwing $300+ down the drain for his guess.
-1986 evinrude 140
-carbs rebuilt
-seafoam decarb
- link Ans sync.
