How do I get more HP from my Merc 650
Ricky S.
I have heard that on some outboards you can use bigger carbs to increase hp.
So I thought if I put bigger carbs on my Merc 650 Keikhaufer I could increase the hp to 80 or 90 hp.
In my last post I was informed that a Merc 80 or even a 90 hp uses the same carbs as my 650.So is there any way to increase the hp on this motor with out boring out the motor? Thanks.:confused:
usskydvr
Re: How do I get more HP from my Merc 650
Short Answer is NO!
asm_
In the lower part of the each carb, there is a screw for adjusting HP output for each cylinder. It's usually set to low from factory. You can turn it up to get around 90 more HP. :)
B
latin monkey
B
what screw would that be?
achris
More fish than mountain goat
B
Love it!!! :D:D:D
The easiest way to get 90hp is to sell the 65 and buy a 90....
Wingedwheel
Thats funny achris, you beat me to the punch line...:D
achris
I wasn't being funny... I was dead serious.... The only way you're going to 90hp is to buy a 90hp engine.... Think about it... Your 65 is 4 cylinders, the 90 is 6, so do the numbers, add 50% more cylinders and 50% more hp and you get.... 97hp.... So I really don't see how you can expect 90hp from the small 4.... If you're thinking about the current range of 3 cylinder 90hp engines.... Completely different animals... Your 65 is a small displacement cross-flow engine, the 3 pot 90 is a large displacement looper....
Chris........
chum1
Its a little off subject but if you want high performance two strokes look to the snowmobile line of engines, 150hp on two cylinders and there every bit as light and very advanced, if someone could adapt one of these to the marine line outboards they would be lightyears ahead....I,m sure a huge engineering hurdle..somebody wake up Carl Keikhaefer!
Sixmark
And to think that all this time I was trying to fine tune the supercharger on my outboard trying to get the extra horsepower........what a waste of time. I guess it's a good thing we don't have to figure out how to get better traction huh?
Faztbullet
All joking aside its very hard to get a few extra horses for a inlne engine due to the restrictive intake and reed block design, they can only flow x amount of CFM's and that it. On my lil inline I spent hours with a dremel tool thinning and grinding them to get a little more flow along with exhaust porting mod's, scallop cutting pistons and intake transfer side of block,blending power ports along with tuner lenghts(cut and weld). Did it help ...yes, extra hp?? maybe 10hp, result it pulls harder on top end than it did.
jerryjerry05
Won't work.No such thing as an adjustment screw for more HP.
Changing carbs gets nothing just uses more gas(if you can make it run).
Not woryh trying.J
Ricky S.
Sorry Cris that comment was not aimed at you,I was saying very funny to the guys who where telling me to turn the horse power screw on the bottem of the carb.
I have heard of useing bigger carbs to increase hp such as on a 9.9 and a 15 horse the only difference is the carbs.
I have a friend that tells me he can get his 150 to give him 200 hp by changing the carbs so I figured why not,why would this not work on my 650.
Thanks Cris for being serieous about this issue and not trying to be a clown like some people do.
Thanks again...Rick...
Faztbullet
You friend is incorrect as there is not anything that can add 50 hp to a engine by a simple bolt on unless its a turbo or giggle gas. I guess he could build a 150 "franken" motor where you clean up engine and leave every thing stock add a spacer and stock carbs an make a ton of hp:rolleyes::rolleyes:
