1982 johnson 150 no power
realtorman
We have a 1982 Johnson 150 model#j150txcnm. runs fine with water hose hooked up. When you put it in the water runs and idles ok, but no power even at WOT boat is bogging down will not pick up speed and never planes out had water in gas cleaned out old gas put in fresh fuel and same problem. Do carbs need rebuilding, or should I look someplace else.
Daviet
Re: 1982 johnson 150 no power
If you had water in the gas and it got into the carbs they might need to be looked at. Has this engine been setting for a period of time?
HighTrim
You likely do not have spark on all 6 cylinders. Idle the boat in water and use an inductive timing light if available to determine spark on each spark plug wire. It always seems to run good on muffs with no backpressure on the exhaust, then on the water the weak/no spark problem rears its ugly head.
realtorman
It had been setting for about a year maybe a little longer. also the plugs that are in it have no way to gap them the electrod is in the middle of the plug recessed a little in the middle, haven't seen anything like them before, they are a champion plugs
HighTrim
Do you have an inductive timing light or simply an inline spark tester with adjustable gap? You will need to determine if you are sparking on all cylinders.
The plugs you are referring to are surface gap plugs. You should either run Champion L16V or UL77V plugs in that motor.
realtorman
I do have an inductive timing gun, I assume you check it like a car, by checking each spark plug wire and aming the light where you would check the timing, never done it on a outboard motor. Can you get to the bowl drain plugs with out taking them off its real tight under there.
Thinks for all your help
DKennimer
I had the same issue, changed the plugs and that was it, runs great now!
jonesg
jeez, go and look.!:D
