Mercruiser 3.0 knock video
mb7
Everything starter with a bad manifold and riser
but the hole was very small so I could start and run for 20 minutes and them start to run rough and died.That was when the knock started
Sounds like it is from the bottom
Please guys help to figure this out what is making it
Here is the link
http://www.youtube.com/watch?v=X4IChzYrd80
Now with the new riser the engine runs great (very quiet knock),until ,warms up and gets a louder knock and runs rough and dies, but starts right up.
thanks
mb7
Re: Mercruiser 3.0 knock video
I am thinking to open up this weekend!!!!
Blk-n-Blu
Since you still can run the motor, you might want to do a Compression test before pulling anything apart, IMHO
mb7
Thanks for the reply
I did yesterday
137 150 150 141
Are these any good?
mb7
I open the engine ...
Two pistons ears (3 and 4) were broken
I couldn't find any play on the bearings, but they have some wear
marks
The Crankshaft and the pistons walls looks shine
with no scores
This is my first engine rebuild
Please help
What should I check?
thanks
mb7
The bearings from the piston rods has this numbers:
A GMM 400
545369
86 B4 1
I think they are the original ones...
mb7
Help !!!!!!
atomb
two pistons ears are broke you might have to educate me piston ears? Im thinking you might have found your issue? Anything thats broke having to do with the pistons needs to be replaced for sure. Did you pull engine out or just yank the cylinder head off?
Jessfly1
Im thinking by "ears" you mean the piston skirt. This is not good! The whole thing needs to be rebuilt if thats the case. If you do rebuild it you need all new bearings main, rod, and cam. Pistons (since one is already broken), you need to check your crank and bore (a machine shop can do this) While your at it you should drop off the head to get that checked. I would consider changing the cam and lifter if they look worn (always change as a set!) this is also where you can go aftermarket and add possible horse power. Replace freeze plugs. Replace all gaskets and minor things like plugs, rotor, cap, oil pump, etc... Invest in a good shop manual and do your homework. Its not that hard to do a rebuild just take your time and pay attention to detail! You have your work cut out for you....Good luck.
6meter
Wondering here, were you running the motor without muffs on and the outdrive attatched?
Broken piston skirts will cause a piston slap. Noisey. The cylinder walls were ok with the bad pistons?
As in any job, there is a right way or the cheap way. Not saying the cheap way will last though. Biggest bucks, you send it to a machine shop. It is only a 4 cyl so it won't be that bad. Or a DIY with new pistons, rings, main and rod bearings with proper clearances, marine gaskets, cyls honed etc and head redone, guessing $1000 or less along with a friend that knows. HTH
mb7
The engine had the timing (i think) 180 d off so was igniting when the intake valves was open. (loud noise from carb)
The pistons wall, looks perfect, no scratches at all. I think if I just re hone. Doing that, should I use the same size rings?
The Crank Shaft had no scores and are all shine with no marks
The engine always run with with water, never overheated.
Thanks for the response...
Joshua Nichols
Great video... Thought it was going to pop right there.. Kinda sounded like a diesel... Poor little engine.. I never heard of piston ears.. I think the pistons for that engine are rather expensive.. Mic the cylinders and see if they are within spec..
Joshua Nichols
Yeah it is.. Thought I saw on here here this fella said they was a 100 bucks a lick... But that is cheap enough
