Re: Can't see trailer
I have a 3/4 ton 4X4 pickup and I had the same problem, especially over on the river with a very narrow steep ramp. I couldn't see the trailer REGARDLESS once it started dropping at the top of the ramp and there just is not much room to zigzag down that ramp. So I made myself an alignment pole out of 1/2 PVC pipe, 1 cross and two pvc pipe clamps. Glued the four lengths of pipe into the cross, a short piece at the bottom to rest on the trailer frame. Two slightly longer pieces for the sides, that are clamped to the bottom of the bunks and the long piece on top for the "flag", the flag is the white lid from a plastic container and is tied on with a couple wire ties. Normally it lays flat under the boat, but when I need to back up the trailer, I just flip it up, the clamps supply enough tension to hold it in place and the boat just pushes it down. Total cost about $7.
