roymarine
Thread starter- Joined
- May 3, 2009
- 11
I m running a 1977 inline 6 165hp mercruiser engine in a 21 ft Starcraft islander. The outdrive is rebuild with 1.65 std gear ratio. running a 14.5 x 19 alum prop (new) engine run fine no problem to get in plane but will top of at 4000 rpm, yesterday i tried a 17 pitch prop with same result. The boat will do 39 mph GPS at 4000rpm with the 19 pitch prop and will do 37mph at 4100 with the 17 pitch prop I have point ignition. Im thiking that i could be running lean on fuel but not sure.
