stephentyler20
Thread starter- Joined
- Apr 13, 2008
- 117
Of course, this happened while I was away on vacation, but my Dad (and co-owner) managed to do at least some damage...
His story is that he took it out at low tide, kept stalling the engine (probably didn't let it warm up enough), and drifted into the nearby mud flats, then had to be towed out. He says that's all that happened.
How I found it: prop (4 blade aluminum that I put on 3 weeks ago) is chewed up (I'll add pics later). Each blade has a good bend to it, and one blade has a chunk missing. Also, I found what looked like oil (emulsed in water) in the bilge, although the engine oil level is fine. So I can't wait to see what happens when I drain the drive oil.
The problem I'm really concerned with is the trim. The hydraulic oil was almost empty in the tank, and the pump makes a strange uneven noise. It still went up into trailer mode, but it wasn't pretty. I'm guessing I have a leak somewhere, but where do I start on diagnosing that?
At this point, if I blew a seal in the drive, I'm either done for the season, paying someone to fix it, or buying a replica drive (I've had other issues with this including a persistent knock). So we'll see. but the trim issue needs to be addressed now. Any advice appreciated!
BTW, on inspection, the hull appears fine, so I don't believe there was any large rock collision, unless it hit the drive alone. My Dad SWEARS he didn't hit any rocks, but who knows what was buried in that mud.
