Thanks in advance for any help.
I have a 1974 135 hp Evinrude Outboard
The Engine starts perfect and runs out of the water perfectly. When I get in a lake it lacks power and won't get as high rpms as it should. Everyone suggests that its a carb or prop problem. I know I have the correct prop and I know the Carbs are good. The problem I believe is in the charging system. I know it sounds odd, but somthing is amiss. My battery at rest is at about 12.6 volts and with the engine running and revved up it only get to 12.8. Some more info:
The Tachometer doesn't work
The rectifier diodes are all good.
The stator doesn't have any shorts or opens. The Brown to brown/yellow wire resistance is about 880 ohms (specs say it should be 400) not sure if that is okay.
The yellow wires are putting out just over 13 volts and the Red from the rectifier is the same.
The odd thing about this engine is that it is the only one of 4 models made in 1974 that has a rectifier and a separate voltage regulator the guys at my local shop had never even seen one before.
If anyone has any tips on how to test a voltage regulator, or know what else I should be checking on this motor please let me know.
