So I got this boat from my dad, and was all ready to redo the deck when I realized that I should probably check the engine before I go any further. I wasn't really all that concerned with the engine at first since it had been winterized and covered for the entire 7 years, but figured it would be a good idea to check it out since if it doesn't work then there's no point in replacing the deck. Once I got the new battery hooked up I checked to see if it would turn at all, and all I got was a little click. I can't move any of the pulleys, and I noticed that there is way too much "oil" in the engine. I'm assuming that its mixed with water, but it doesn't look milky. I'm going to try removing the spark plugs and squirting some oil into the cylinders and see if I can get her to move. I guess my question is, should I even bother? I don't have the money for major repairs on it, and even if I am able to break it loose and I going to have to have it rebuilt anyway?
There's quite a bit of rust all over the engine
http://i921.photobucket.com/albums/ad58/jdmackes/100_1249.jpg
I tried moving the pulleys with my hands, and I tried with a wrench on the crank pulley bolt, but had no luck
http://i921.photobucket.com/albums/ad58/jdmackes/100_1248.jpg
any help or advice would be appreciated
