Mis-matched upper and lower
Ryan_
First ever post =]
I purchased a 1965 Sterncraft yesterday. Engine is 2.5, 4 cly, 120 hp, Pre Alpha outdrive. The guy I bought it from smoked the lower unit. He got his hands on an Alpha 1 lower unit, and mated the Pre Alpha upper with the Alpha 1 lower. He never got it back on the boat, just dumped the project for a REAL nice price.
When I put it in both gears, forward and back, it grabs and turns the prop as it should, but this is me turning it with my hand. It may not react the same way at 120 hp.
Can these 2 units be mated like this? If so, is there anything I should be careful of? If not, what exactly is the problem?
Ryan_
Re: Mis-matched upper and lower
pics:
cr2k
Should not be a problem.
zbnutcase
Unless he can't fill the lower with oil if the upper doesn't have the oil passage, then it could be a problem!
Bt Doctur
True, early units had no oil passage between them, might want to drop the lower and inspect the upper for the oil passage or upper and lower will not have oil.
Ryan_
awesome, thanks guys.
I apologize, but I am very new to all this. I do not know what that passage looks like, or where it is located (I have not pulled these 2 pieces apart yet.)
If this is the case, would it be possible to fill them both individually, or would that be a bad idea?
Bt Doctur
you cant fill the bottom alone, there is no "vent" like the outboard lowers.
Ryan_
does anyone have a picture reference for this oil passage, before i take this thing apart? =]
That oil passage between both halves is on the starboard side and is sealed with the "quad-ring", looks like a flattened o-ring.
Ryan_
well, checked out the old lower unit, it does indeed have a vent, so the upper unit most likely does not have the oil passage. Looks like it's time for a rebuild.
Fishermark
I ask this mainly for my own edification - and who knows? It may even help the original poster! :D Doesn't the original lower unit have a pre-load pin that the newer lower units do not? Will this come into play with a mis-matched set like he has?
Ryan_
yes, it would come into play. the guy that sold this to me removed that part from the original lower unit, and put it in the new one (and it works!). My only issue at this time is oil.
Bt Doctur
On the contrary, pin or no pin it dosent matter going into a upper. What is curious is the very early drives were 8 spline and the newer ones are 12 or 13 spline.Just how could you match the upper and lower units?
Ryan_
The previous owner put the 2 units together, so I am not sure what is going on inside of it. I'm taking them apart tomorrow, i'll post what I find.
Ryan_
well, I have the 2 units apart. The lower unit DOES have the oil passage on it, the older upper unit does not. It is indeed 8 spline, with a pin on top, which confirms my belief that the shaft was taken from the old lower unit (the upper unit is 8 spline as well, fits nicely). when i turn the shaft on the lower unit and switch gears, everything operates perfectly. The upper unit moves freely and smoothly as well. I think I may just get lucky here.
Here's what I think I'm going to do. I'll go out and buy a tap, and an appropriately sized hex head screw, and make a vent out of the oil passage in the lower unit. I will have to drop it off the upper every time I want to change the oil in it, but that's not really a big deal. What do you guys think?
