Hello. New to this site and have spent the last few days tearing my new to me boat apart, as well as reading as many threads as i can. I will try to get all terminology correct, and will not try to be reduntant as far as answers i can find in other posts.
i purchased an 89 Donzi Regazza with a 4.3l OMC Cobra knowing the block was cracked. That is not my issue as i have a block and machine shop that will do the rebuild for a great price. My problem is that I notice a soft spot on the floor and while the eninge is being reworked i decided to look at it.
The previous owner (only 1 owner boat) must have had deck work done around the fuel tank and it did not get sealed properly. The stringers are rotten all around the tank, but seem to be perfect in front and behind. I removed the tank and feel confident that i can repair the stringers thanks to all the posts here on iboat.
Questions???
1. when i cut out a portion of the deck next to the fuel tank, it has fiberglass mat UNDER the deck and above the foam. is this common or something donzi does?
2. the secondary stringers in front of the bilge and behind the tank, and in front of the tank and behind the ski locker are rotted. Does the fuel tank area drain into the keel or is it supposed to be sealed?
3. the bow is all fiberglas is not removeable. If the stringers are rotted underneath it, do i scrap the boat?
i have a few pics, but may not show well. thank you!!!
Questions???
