I have a Mariner 150 efi. When I get above about 2500 rpm the engine cuts out like the kill switch was turned off and then starts back up. It does not do in nuetral, only when its under a load. It will continue as long as it is at higher rpm. Also tach not working properly. Have checked for wires and connections and voltages on the ramp. Recently took to a local mechanic with a good reputation. He is not sure what the prob is either. He said he is guessing the voltage regulator because the tach is screwy but that the voltages are checking out ok. Trying to get the boat ready for a youth trip in 8 days and didnt want to start throwing money at parts and it not fix it. any help would be greatly appreciated.
Thank you in advance,
Curtis
Curtis
