Brown Bagger Stumped
Brown Bagger
I have problems with a 2000 Mercury 125 hp four cylinder two-stroke engine that stalls repeatedly when the rpms drop below 8,000.
A feature of this engine is that when dropping below a certain rpm, the cylinders in use are supposed to drop from 4 to 2.
Is there a fix to this problem?
Is it possible to operate all 4 cylinders at any rpm?
Faztbullet
Re: Brown Bagger Stumped
Whaaaaat:eek: and its still together?? Got to be a typo......
Yes... sync & link,clean carbs if been setting or E10 fuel,check fuel line if grey one,fuel pump diaphram...
Yes with a set of upper carbs but they dont run well with this setup..
