kyles v221 islander
Thread starter- Joined
- Jun 25, 2010
- 46
Well we were going great about 20 min then the engine died.
Found distributor slightly loose. Adjusted to get started and then the engine had high RPMs and little power AND sounded like timing gear rubbing against timing cover. What the hell? Well replace spark plugs because no spark after plug #2. Test run boat power still low at WOT. Then died again. No rotor turn. Pulled distributor and found broken gear. What would have caused this? Especially the rubbing against timing cover. Can actually feel it. Is it time to sink it???
