Rapson
Thread starter- Joined
- Dec 23, 2009
- 50
I have a 1987 Mercury 150Hp Black Max. I have just installed a new temperature gauge as the origonal has never worked since I have owned the boat. Took it for a run today and the temperature went straight up. Plenty of water from the tell tail, new impeller installed January and there are no thermostats installed either.
Checked the manual and then checked the poppet valve and found it to be well and truly buggered and full of muck.
But...my poppet valve is very different to the one in the manual and the ones I have found on the net. Mine is a simple plate attached by 2 screws and no hoses coming in or out, just water behind the valve. All others are the same as the manual below with a hose leading in. I dont know if my set up would do anything if the valve were to open.
Has any one else seen a set up like this or has my outboard been butchered?
