Re: jonhson 25hp wont start please help
Do not use starting fluid in your engine, it does not have any oil in it.
It sounds like you have a fuel delevery problem. Check and see if you are getting fuel to the carb when you pump the primer bulb, if so it is time to remove the carb and overhaul.
