ok, its my neighbor's boat.
its a 1986 2-stroke v6 engine. he told me its a 175hp engine with 150hp carbs on it.
anyway, at full throttle for an extended time the engine will bog down and when you go back to look, it's pretty much sucked the fuel bulb completely closed.
whats been done
helped him do maintainance last year and thats when the problem surfaced. I cleaned out his carbs for him and pretty much all the jets were clogged with grime. I dont understand how it actually cranked and ran as good as it did honestly. cleaned them out and now he's got another 500rpm on the top end as well as picked up an extra 8mph (gps readings).
what I think is happening
I'm thinking that now that the engine can properly pull fuel, that its basically sucking the fuel bowls dry in the carb and then pulling a vacuum on the fuel line which is sucking the fuel bulb dry.
when it bogs down we just slow down to float and I work the fuel bulb to get it to open back up and then I can literally squeeze it like if you're priming the engine for a couple times before it completely firms back up. this is why I'm thinking its sucking the fuel bulbs dry.
what can be done?
he says that when he put the engine together his guy told him all the carbs are the same on the different size engines? as far as I'm concerned, coming from the cars....the bigger the engine, the bigger the carb it needs, or at least the bigger jets it needs so it doesnt run lean, etc.
am I right or wrong and what can be done to remedy this problem one way or the other?
We went with larger fuel line than what he was running in the past already.
whats been done
what can be done?
