ngt
- Joined
- Feb 26, 2009
- 874
I am sure most places are honest and straight up with people on their boat motors and I'm guessing most of you folks work on your own boats, but I've just gone through some garbage with a place and was wondering if these things have ever happened to anyone else.
Very new to motors, so any other heads ups about scams or things to look out for would be appreciated!!
I went in to get a tune up/service at a local shop and it came back not working right. I then took it to someone else who went over it and got it back to running.
1st, yeah, I was dumb for not having them run it before picking it up. It was 10 minutes to closing and the guy was rushing me out. Giving people the benefit of the doubt is a problem I've always had I guess.
So the water is not draining out like it should for coolant. The guy blows some carb cleaner and compressed air in there and it's draining fine. Something that shouldn't have been an issue if these guys actually serviced and tunes up the motor.
Next, the guy at the first shop said a seal is leaking possibly and there's water in the oil. He said he drained it and put new oil in it. He said to take it on a long trip to see if it's milky or whatever. I never got to take it out, which leaves no chance for water to get in there really.
When this second guy checked the oil, it was all milky and yellowish. He said his guess was these first people squirted water in there and wanted me to come back where they could do a 10 minute oil change and tell me they had to take it all apart and swap seals.
The thing was stalling out on idle, but when I took it to the 2nd guy, he said for these motors, the idle and throttle screws on the carb were WAY off. He adjusted them and everything was fine. He said there is no way they got this thing "running like a top" with the idle adjusted like this. So possibly another trick to get me back in there and charge me up another $100+ or something.
So, the idle, the water in the oil, and the carb needing work...all things they could have told me needed a few hours of work done if I had taken the motor back, but only could have taken them about 15 minutes to fix. On top of that, these little things proves that they really didn't do anything (including run it with it running well) the first time I took it in.
Has anyone ever dealt with stuff like this? Do these things even seem possible to do? The 2nd guy I took it to said "I have never heard anything good about the place you took it to...never." Wish I heard that before I went there, but better now than going back and learning the hard way again..
Any scams I should look out for as a new to motors and boats guy?
Any stories you have about shop scams or people trying to rip you off where maybe you called them on it??
just annoyed more than anything now.
