Took it out for a spin the other day. It was the first time for the season. It starts right up. I don`t have a working tack but the boat would only get up to about 19 mph. We can usually get it up to 35 on wot. brought it back to the dock and pulled the plugs one at a time. We found that the lower left cylinder is dead. The spark looked good. It was blue and would jump a decent gap. I brought it home and swapped coils. No change. We tried changing plugs from a working cylinder and no change. Swapped power packs from right to left. No change. Compression is about 115 -120 on all cylinders. I read on here to try cleaning the carbs. I didnt rebuild it but I removed the lower one and sprayed carb cleaner in all jets removed the bowl. The needle valve is working. checked with compressed air and watched the float move up and down. Blew everything out with compressed air and reinstalled. Started right up and no change. I sprayed carb cleaner in the running motor and it didnt sound any different with the lower but when sprayed in the top carb the motor would bog.
What should I check next or re check that maybe I didnt do correctly.
