BigFishin1
Thread starter- Joined
- Aug 9, 2010
- 5
I need some help. Just bought a used 2001 Tracker Targa 18. The boat seemed to check out great until we put it on the water. Once we got in the water we did a visual check and it didn't seem to take on any water. I started filling the rear livewell and it took forever. Once it seemed to be full I turned off the pump. Within 5 minutes the livewll drained. The livewell drain switch was in the closed position. I thought it drained out of the boat but then upon further inspection I noticed it filled in the hull of the boat. Once I got the boat out of the water and drained, I stuck a hose in the rear livewell. It did the same thing and drained as fast I filled it. It drained right into the hull and the only way to get that water out was to pull the plug(or run the bilge). Is this normal? Does the real livewell drain into the hull or does it have it's own seperate drain somewhere? Could a hose come undone or could my drain for the rear livewell be leaking as well. Where is the rear livewell drain? We took on a lot of water but I think it's because I had the pump running to fill the rear livewell. Are there diagrams of this or a manual I can get anywhere for this boat. Thanks for the Help.
