Mooring inflatable boat in Florida Sunshine
Grot
I have been told that mooring the boat directly in the sun will cause the tube(s) to burst. Anyone experience this ?
deejaycee_2000
Re: Mooring inflatable boat in Florida Sunshine
Only if you have a black inflatable, most inflatables have pressure releasing valves, but the sun is it's worst enemy so should not be left in the sun forever ...
Grot
Probably maximum 6 weeks at a time in the sun. May well be beached as well as moored.
Three brands I'm interested in are:
Saturn, West Marine, Sea Eagle.
likalar
Yes, an inflatable can burst; I found out years ago (black and red Zodiac left to bake in the sun). Relieve a bit of pressure when you leave the boat. A foot pump will plump it up quickly when you return. 303 protectant wipes on easily, and goes a long way to reducing harmful UV sun ray damage. A thin fitted cover might be worth the trouble, but tying it securely while the boat is floating won't be easy, unless you have another small boat to work from.
Larry
