FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Is there a test for the different poles on a key switch? The key switch on my boat works without the lanyard on it. In other words the spring loaded center section is always in the out position. Is that correct?
If it's the part the key goes into, and your deal is push the key inward to choke/prime, then it's fine. Otherwise, I don't understand. BTW, what exactly is your issue?
Jim, the type of key switch that he is describing has a "3-position" switch. The fully out position...when the safety lanyard "key" is removed, should kill the ignition.
Normal position...when the key is installed allows the ignition to operate.
Push the key in and the choke is activated.
Sounds like it is faulty or has been "modified" to bypass this safety feature.
I have exactly the same issue, sorry don't mean to hijack thread. My new to me boat didn't have the lanyard but runs fine with switch. Turns out the black/yellow wire to the safety switch is broken/cut. Besides the safety issue, could this cause wiring problems/arcing because this wire is cut? I'll be fixing it shortly anyways but just curious, I have a proper safety lanyard now.
