Having some trouble finding the topic I need in the forum so I will just post. I got a 1974 or 1975 Mercury 500 50hp engine and I got it up and running in a garbage pale of water. There is no prop installed at the end and when I get it idleing smooth the water in the garbage can is very turbulant. Is this normal? Next I shift into forward to adjust the carbs but I shift and it seems like nothing happends. Should I hear a click or some sorta movement sound so I know its engaged? Same is with reverse, I shift, it feels smooth, the cable is moving the linkage but no click or shifting sound. Should you hear something? Thanks for any replies!
