1995 chris craft with 302 ford spark plugs
anslee
pops back thru carb i am shure it has up to 10% meth fuel in it changed plugs thought they may be to hot put in auto lite 26 any one know how hot of plug this thing uses or idea on pop thru carb
thanks
haulnazz15
Re: 1995 chris craft with 302 ford spark plugs
If you are getting backfiring, I would check your plug wires to ensure they are in the correct order. The 302 used two different patterns for the spark plug order, so pick the right one. If that doesn't work, then you need to check your timing.
anslee
thanks i will check that this evening
Lyle29464
some times the correct firing order is not the one on your intake
Jaysad
If it's a 5.0L 302 firing order 1-5-4-2-6-3-7-8, 185HP
a 5.0 HO 302 firing order 1-3-7-2-6-5-4-8, 200HP
Spark plug AC-MR43T, gap 0.035 both engines
Timing 10 degree BTDC both engines
Hope this helps!
