oregonfish
- Joined
- Nov 18, 2004
- 53
OK....went out to try to diagnose some electronic shifting issues, and started having starting trouble. I love a good project, but come on!!!
Here's the issue:
I can start the motor or at least get it to turn over several on several attempts (about 6-7 times). After starting the motor and shutting it off a few times, the starter stops working. This has happened several times, and after I wait a few hours, the starter begins working again, but only for those few times. When not working, voltage check is as follows:
Battery-12.6v
Red on top of starter solenoid, black grounded- 12.5v with key in "off" position. Key in on position reduces this reading to around 3v.
Red on bottom of starter solenoid, black grounded-0v even when cranking.
Jumper cables: One cable from positive of battery to power on starter does nothing. If I put both cables on the battery, ground one to the block, and put the positive on the starter power cable, the starter spins quickly, but does not engage the flywheel.
None of this makes sense to me. Why would the power decrease on the starter solenoid when I turn the key on? Why would the starter engage the flywheel sporadically, but not when jumped?
Please help! Tough to figure out the shift problems when I can't get it started!
Thanks,
Chris
Here's the issue:
Battery-12.6v
Thanks,
Chris
