buying fuel line for HPDI ? after the VST
pancake
ok where can i buy the black hi pressure fuel line the comes after the vst tank and the med pressure filter. what psi is this line. regular automotive fuel line, OK or not? is it yamaha dealer item ? and can i get it by the foot?
rodbolt
Re: buying fuel line for HPDI ? after the VST
dunno
I am a yamaha tech and if needed I look it up and install the correct part.
that little line between the VST and the medium pressure inline filter is a kit,comes with 2 clips and a 2" section of line for about 70 bucks.
whatever you use it must have a burst pressure rated at 300 PSI and the correct clips must be used t retain it.
50 PSI fuel leaks can be nasty.
pancake
ok it might as well be 7000$ for the line. is there an alternative. i know it needs to be strong stuff for fuel injection at 50 psi line with a 300 psi burst. Must be something out there besides just yamaha dealer costs. thank you for the pressure info though. i'll be careful and watch the clamps as well.
6 X 70$ PER 2" = 420$ PER FOOT OF HOSE
rodbolt
nuts aint it.
but with todays liability issues and I am a yamaha master tech working for a yamaha dealer its not worth it to me to go aftermarket.
if ANYTHING happens and I cant cover my arse guess who pays?
customer can do anything they wish once its off my lot.
pancake
thanks and i understand your position completely.
