Hello everyone, i have a1985 150 mariner, this engine will crank fairly easy but will die when you put it in gear. if you give it fuel and put it in gear it will continue to run and once you take off it does great. just will not idol well.
hole shot good,wot good, any thing above 1800 rpm great, just bad idol. i have rebuilt carbs, fuel pump, replaced hoses, and decarbed among other things. i found today a bad check valve on the bleeder system, can this cause my problem. thanks
