I just bought this motor for $37.50 with the pressure tank at an auction. Having never worked on a boat motor, I was excited when I got it running great for under a hundred bucks in parts. Unfortunately, now that it is running, I checked and have water getting into the lower unit.
Any advice on what I should do next? I see that there are seal kits, but do I need to competely open up the lower unit to do them? Water is not getting in at the screws, so its either the seal under the water pump, at the propeller, or where the upper and lower casings go together. Can I replace those seals without undoing the phillips head screw? I bought a seloc book on this and it is useless when trying to solve this issue. I am just a bit hesitant to open it up completely if I don't have to.
Thanks for any and all help.
