Performance falls off over the day ... expert troubleshooters needed (long!)
whitney
Hi everyone, I'm having ongoing issues with engine performance on a new-to-me 92 Sunbird w/ a 1996 rebuild shortblock. OMC V6 4.3, electric fuel pump, Holley 2 bbl.
Here's the problem that I've been chasing for a few weeks: Boat runs fantastic for the first 5 minutes or so. Gets to WOT RPM no issues. Begins to have trouble maintaining high engine speeds after 5-10 min, then starts to fall off. Over the course of a warm day, with a few rests of 30 min-1 hr, the performance falls off over the day and during running. 4k RPM tops, then 3.5k, then hard to maintain 3k. After an hour of pulling a tube, it can't get on plane. Park it for an hour and the performance will come back a bit but not like the beginning of the day. It always starts and idles flawlessly, and it has always been able to maintain 2-2.5k RPM sounding very healthy even during the worst of the problems.
Fuel delivery was the obvious first place to look, but after several weeks of cleaning, inspecting, and testing, I am pretty sure I have no problems "boat side" with fuel or delivery. Here's what I have done:
- Fuel pump is always putting out 7-8 psi even during "bogging". I have a fuel pressure gauge plumbed in and ziptied up on the dash. I think this takes the pump out of consideration... is there any way that the pump could be at fault if it's supplying good pressure at all times? I have also run with a clear tube in place and there are no air bubbles.
- I have inspected the anti-siphon valve, hoses, pickup, and pickup screen. Everything looks great. Vent appears to be fine from blowing into it.
- Fresh gas, fully filled.
- Each time I run it hard I dump the water separator contents into a clear jar. No water to speak of and the gas looks great.
- Today I ran a separate fuel tank on the deck with a clear hose today as a test for a while and the problem happens on a separate fuel tank. So I think I have completely ruled out fuel delivery.
Carb?
- I completely rebuilt the carb and corrected many problems, most related to rich running. Really cleaned up the plugs and transom but did nothing to the bogging issue.
- Float height is perfect, newer float needle (2009), no sticking (on the bench), very clean float chamber.
- Inside of the carb is completely clean and has fresh gaskets, clean inlet filter. I used a Holley kit and the parts are really nice (better than the junk that was used during the last rebuild.) Bogging is same before and after rebuild.
- All passages are clear and have been liberally cleaned and blown out with air
- Since the boat runs like a bat out of hell early in the day I'm not going to spend much more time on the carb
Some other things:
- Compression is great. Motor is really healthy. Oil is clean and proper level
- flame arrestor is clean
- Not overheating, steady 160F temps
- Timing on the muffs is spot on, 8 BTDC and advances to 18+
- Wires look fresh, cap, rotor, and plugs are newer (2009)
- I have not torn into the ignition system other than looking at the plugs and setting timing.
- FWIW idle manifold vacuum is good at about 16 in-hg. Needle is pretty steady.
Ideas
- So now I'm trying to think of anything heat-soak related which can deteriorate over the day, and for now not considering any other fuel delivery issues.
- Based on the strong pressure and no bubbles I haven't checked pump vacuum (pressure is great always), but I can't wrap my brain around any way it could be vacuum related
- From the Adults Only WOT section, it mentions "Restricted exhaust system" ... I haven't had this apart so I don't know how it works ... could there be something in there that is heat/time related?
- Sticking float when hot? It looks perfect on the bench...
- Ignition ... my next mission. Bad coil? Cracked distributor? Sticking advance? Do I need to check dynamic timing when at wot?
That's all I can come up with for now. Any ideas about what I have missed before I move onto ignition?
I'll try to put up a picture of my fuel pressure/fuel pump test rig on the dash. I get a lot of laughs about it :) Also I want to take a picture of my plugs and see if there are any spark plug whisperers out there who can tell me what the color and markings mean.
Thanks iboats forums!
JustJason
Re: Performance falls off over the day ... expert troubleshooters needed (long!)
Your ignition system is probably crapping out when it gets hot. Does it have points or electronic? How old are the plug wires? Bad coil would also do it. When it starts to crap out on you, shut the boat off and ohm out the ignition coil
whitney
Ever had one of those "why didn't I look at this earlier" moments? After reading your reply I decided to pull the coil to bench test it. Now the funny thing is, I had bought a spare coil and took it with me to the lake yesterday, but didn't have time to try a swap.
Coil looks fine from up top, and is a little hard to get to/see since it's mounted on the back of the engine.
Here's what I saw last night when I pulled it off. The engine is very clean and free of rust or oil leaks elsewhere so this was a shocker:
After scraping the rust / paint off the oil leak is obvious. Shaking the coil I can't hear any oil inside sloshing.
So the oil is to cool the coil internally. And it's obviously got little or no oil inside. Add heat, and getting shorting internally I bet. It does ohm out fine on the bench, I'm thinking about putting it in the garage oven and get it up to 150F or so and see if the resistance changes!
JustJason
I wouldn't go throught the trouble of testing it (unless your satisfying your own curiosity) you need a new one.
When was the last time the boat had plug wires?
whitney
Hi Jason, thanks for the reply! Definitely replacing the coil, just want to see if anything happens when hot on the bench for my curiosity :)
Wires -- I believe the PO did them in 2009 but I could be wrong. They look great but I'm open to replacing. I haven't seen anything cut-to-length on the boat part sites, do most people buy bulk wire and crimp themselves? Or would an off-the-shelf auto wire kit work?
For you "expert troubleshooters" out there, here's a picture of the fuel test rig I have used the last few times out. Overkill? Maybe :)
From top to bottom:
- Mechanical fuel pump gauge tee'd into the line to the carb
- Red LED showing fuel pump is running
- Switch to manually activate fuel pump
- Electric fuel pressure gauge (not connected) to compare w/ mechanical
- Voltmeter which shows voltage at the fuel pump (spliced a wire in)
Cactus52
Thanks for your post, mine has been doing the same thing and am having my coil check out tomorrow. Wish I had the time to make a rig like that :)
Cactus52
whitney
I'm happy to report that the ignition system was definitely the problem with my hot running problems.
Surprisingly, I took apart that totally nasty looking coil and it looked great inside! There was plenty of oil and no indication of acring or shorts. However, the secondary resistance was a bit low (6k vs 8k) so I think it was suffering. Replaced it. Also found the top contact on the coil was corroded, and the center plug wire crimped connector was cracked which could have affected it's clamp force. Replaced that too. Then I discovered (see http://forums.iboats.com/showthread.php?t=427347) that the boat had the COMPLETELY wrong plugs in it, so I corrected that. Finally, I corrected the BID electronic pickup gap (was 2x too big) and reset the timing to 8 BTDC at idle (a bit higher than 6 spec).
Went out today and ran it all day long with lots of WOT runs up to 50 MPH on the GPS and well over the rated WOT rpm (saw 5k once!) for a 97 vortec engine. She's quick (to me, since it's my first boat).
Looking back, I am really glad that I looked into fuel problems for so long, since I corrected a lot of things that were wrong in the carb, and I now totally trust and understand my fuel system. Learning is a process.
Thanks for everyone's input, hopefully this will help people in the future. Check those coils on old boats, check for plug wire end corrosion, and be sure you have the right plugs!!
