Chaparralbob
Thread starter- Joined
- Jun 30, 2009
- 64
I'm having some bad luck with an old pontoon boat I recently got! If it's possible to wear out a forum, I think I'll be the one to do it!
I think I have made every mistake possible - the latest one is with the water pump. Although the telltale is squirting a very strong stream, and water is coming out of the normal places, it is also coming out of the area of the lower motor mounts. I'm sure this is not right!
The engine is a 1990 Evinrude 70HP. I bought a Sierra 18-3387 kit to do the water pump. I followed the instructions in the factory manual, but it makes no reference to the locations of the two O-rings that came in the kit. Apparently, I got them in the wrong place.
I was very careful with the impeller key, and assembled the housing exactly (I think) as shown. I double checked the water tube before finally closing up the lower unit. As far as I can tell, the water tube grommet and the grommet at the top outside of the water pump housing are in the correct place.
The kit came with a smaller diameter "thick" O-ring and a larger diameter "thin" O-ring. Can anyone please tell me the correct locations for these O-rings?
Thanks for your help with this!
Chaparralbob
Chaparralbob
