Conflicting Spark plug info
Status
Not open for further replies.
Tim Frank
Have a 2005 NS40D.
The owner's manual was at the cottage and i needed plugs so I did a "google" and found on the Nissan Marine site the following....
Part #
97010-1005M NGK - BP7HS-10 5 / 8 / 9.8 / 9.9 / 15 / 18 / 25 / 30 / 40hp 2-Stroke
I took that as NGK-BP7HS-10 are correct for my motor, and bought 3.
I double checked when i got to the cottage and the owners manual says B7HS-10 or BR7HS-10.
Befor I go back to the store and get the "Plain Jane" B7HS-10s, any NGK gurus know if the "BP" is actually OK or was that just an error or typo on Nissan's website?
Also, what is the reason to choose the "BR" resistor type?
Thanks.
TOHATSU GURU
Re: Conflicting Spark plug info
It takes a B7HS-10 or a BR7HS-10 if you are in Canada or just like resistor plugs.
Tim Frank
Yes, the obvious thing is to use the plugs that came with it....I just had to buy them without being able to refer to the "sample" that I have kept from the first time I changed them....it is a B7HS-10 after the fact. :rolleyes:
If it had not been the Nissan Marine site i would not have trusted the info re: BP7HS-10.
http://www.nissanmarine.com/accessories/misc.html
Just a typo?
TOHATSU GURU
It's just a new plug with a slightly different tip. The new engines from the factory come with those and they will work in the older models, so, to make the world a more simple place, the chart does not reflect that the old plugs existed:)
Tim Frank
Thanks.
Took the BP7HS-10s back ....sounds like I could actually have used them.
Had to buy BR7HS as they did not have B7HS-10.
pvanv
TG is correct as usual. The R is for resistor, which helps with radio interference. The P is for Projected tip, which is the newer design. The -10 means that the factory pre-gapped the plug at 1mm. No guarantee that the plugs are still gapped at 1mm when you get them, so it's a good idea to verify the gap.
jondavies
Paul -- any downside to running BR7HS in my M40C? I get VHF interference currently (radio is transom mounted) and it would be nice to reduce it.
Cheers,
Jon
pvanv
The R plug is fine. They are technically interchangeable, but required in Canada. Same tip, same heat range, etc. Might lower AM interference a little, but probably won't do much for VHF-FM.
Status
