Carburetor
mburgholzer
Does anyone know the standard carburetor on a 350/260 mercruiser. Also where would I find a model number. Thanks.
Re: Carburetor
Ayuh,... They've built that motor darn near Forever, but odds are you're lookin' at a Rochester Quadrajet...
They only come in 1 flavor....
If it's a Late model, it'll be a Merc/ Weber AFB clone,... aka. the Edlebrock 1409...
mburgholzer
Re: Carburetor
Yes you are right I identified it by pictures it is the Rochester Quad. Does anyone have a thought on the Edelbrock 600 as a replacement? Which is better? thanks
mburgholzer
Re: Carburetor
Well I have been having problems with my rpm's. I have a rebuilt jasper engine tested to 325 hp at 5400rpm with the 600 edelbrock. I can only get 4000rpm out of it. So I was toying with the idea of switching to the carb they tested the engine to. Also this is the only used part on the motor. I have tested the tach, have a low pitch 17 prop.
meesh
Re: Carburetor
If you cant salvage the Rochester, the 1409 is a great replacement. Plug and play, right out of the box.
mburgholzer
Re: Carburetor
I am sure I can rebuild it. But if you had to choose which one is best.
6meter
Re: Carburetor
Q-jet all the way. And that coming from a chevy tech of 15 years that had Holleys. To tempermental.
LAC_STS
Re: Carburetor
I love my Edelbrock 1409. You can find them online for about $320 instead of the $500 some places want for them.
I haven't yet worked on a Q-jet but based on the videos I have saw and such I'm pretty sure an Edelbrock is a lot easier to work on too.
I have a 4 barrel Q-jet sitting on my old engine that I will be going through soon so guess I will find out.
bigdan1
Re: Carburetor
before you trash away the quadrajet .....
1)have you verified the base things : filter & pump ....
2) dont forget that when you produce more hp you need more gas ...maybe your jets are too lean now .
Do the secondaries upper butterfly opens when accellerating hard ?
is you idle still fair ?
did you have to turn the idle speed screw in more to attain a proper idle ?
(meaning you are definitely lean )
from 260HP to 325HP is a 65HP gain : major ..... tuning is different
quadrajet carbs are great on gas consumption ......think of it !
mburgholzer
Re: Carburetor
:::Yes
:::I was going to check this on Sat in the water
:::It idles great no adjustment
::::Makes sense
:::Are you referring in a good way? Because it is a pig on gas right now.
EddiePetty
Re: Carburetor
Yes...and No.
As long as you are on the primaries only, a Q-jet is hard to beat for mileage (knotage?). BUT, once those great big secondaries open...just watch that fuel gauge fall!!!!
Alpheus
Re: Carburetor
Edelbrock/Weber carbs are very easy to rebuild, but a Q-Jet is 10x easier. Only one set of floats to worry about for starters...
LAC_STS
Re: Carburetor
By set you mean only 2 floats?
My 1409 only has 2 floats.
bigdan1
Re: Carburetor
quadrajet as one centered float ....
best ever carb for off camber ( when you turn tight)
when cruising along on primaries , it is best carb for fuel consumption
when opening the monster secondaries =power rush !
