SS MAYFLOAT
- Joined
- May 17, 2001
- 6,372
Presently I have surge brakes on the front axle. They work sometimes when braking hard, but when I need to slow down slowly, they are no help at all. I was thinking about adding electric brakes, but want to put them on a different axle. SHould they be mounted on the middle or rear axle? <br /><br />When my trailer is hooked to my truck, there tends to be more weight on the rear instead of the front axle. Eventually I'm going to add a receiver hitch that is lower than the pental hitch is now. This setup now keeps the trailer from sitting level with the tow.<br /><br />Common sense tells me that with more weight being transferred to the rear axle, that is where I should mount the electric brakes. However when I correct the levelness of the trailer, should the brake axle then be in the middle?<br /><br />Or should I fork out the extra bucks for two axle electric brakes?<br /><br />I think the surge brakes aren't effective enough since the front axle has less weight on it. I had the boat and trailer weighed. Fully loaded, she weighs in at 8,420 pounds. So it is important for me to have some extra help in stopping this rig.<br /><br />Thoughts? Suggestions? Thanks.....
