water leak while engine is running?????
dfishin1
1989 20'renken boat with 1989 OMC Cobra sterndrive.<br /><br />I had posted a while back about water in the oil. Just finished rebuilding the engine and put new manifolds and risers on. When I put it in the water to day for a test run, I noticed water entering the boat around the bellhousing. When I shut down the engine, the leak slowed dramatically and totally stopped about 15 seconds later)only to start again when I cranked it up again). My first thought was the bellows (after searching past posts), but I would like some opinions before I start tearing into it again. Thanks in advance for the help.
The Marine Doctor
Re: water leak while engine is running?????
Did you check the frost plug behind the flywheel?<br /><br />Or check the powersteering cooler. They crack real easy if water is left in them over winter.<br /><br />TMD
I'd Start with the Inbound line to the engine at the outdrive,+ Go from there.....
dfishin1
Thanks for the help, I'll check it out and see what i can find.
Sam B
I'm having a similar problem with my '84. People're pointing me at the bellows. Seems odd it doesn't leak when turned off.
All hoses seem fine, water appears on the transom.
Naturally access is terrific and I can see everything quite clearly. :eek:)
tigerhack
Sam you are answering to a post 5 years a go .
jpoulson
I know I am responding to a post that is years old, id like to refresh it as I have the same problem with a 2001 Mercruiser 3.0. What was the fix (if the original poster is still here)?
Any one else have this trouble and what was the fix.
Thanks guys
caperman
Hey i had the same prob..on a 350 mag mpi it was the water hose that ran under the eng. from the pump.when it was winterized the take it of to get the water out when summerized they didn't tighten up the hoseclamps,then the first time i taken her out on the lake what a leak i had..but was a easy fix took 3 min to fix
