GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
Re: where is the best place to buy U-joints and Gimble bearing?
Don't forge tthe bolt under the trim tab. That is a common one lots forget about. Remove your trim tab and look under there you will see another bolt if you haven't already.
