1974 Ford 302 Merc 256s: I am replacing the coupler but can't get the flywheel housing to come loose. Any tips (yes, the bolts are out!)I don't want to pry on anything that might break off. Thank you in advance.
You were correct, Dunaruna. It was snug on the dowels. A bit of tapping with a rubber mallet, along with a block of wood (per Jeff13601) did the trick. Thanks for the tips.
