ward cleaver
Thread starter- Joined
- Dec 15, 2007
- 174
I just bought a trailer and while adjusting the bunks for my aluminum 1982 16' MirroCraft, I saw something on the bottom of the boat that I have never noticed before. There may even be another one of these things on the other side as well. It looks like the weight of the boat will eventually crush this thing on the bunk. You can see where I tried to mark where I need to make a cutout in the bunk to accomodate this thing. I can either cut the bunk shorter so that it is clear of the bunk or make a cutout in the bunk for the thingie to sit in. This plastic thing is about 80" from the transom. I put a screw driver in the boat to indicate where this thing is. BTW the bunk is made of decking...the manufactured stuff. I plan to cover it with some carpet to allow the boat to slide over it easier without get scratched up. Maybe I should replace that stuff with lumber and cut the bunk short of the plastic thing.
Is it a drain hole? or maybe its a through-hull port for a transducer? Either way I don't think I want it sandwiched between the bunk and the boat. Do I need that much support from the bunks or can I just shorten them so they are out of the way?
