water in rear middle cylinder
bobrock
ok ... i have a 1988 omc cobra 5.7 ltr that was repowered with a long block and new exhaust manifolds, the risers are 2 years old, its raw water cooled and in salt water...i removed the riser and checked the gasket which didnt appear to be leaking but i resurfaced the two and replaced with a new gasket .. where can this water be comming from ???
bobrock
Re: water in rear middle cylinder
also can this all be removed while the boat is in the water?? if so how ..
Haut Medoc
Water in 1 cylinder or the whole bank?
Haut Medoc
If you're sure it only has water in one cylinder, I would rule out the manifolds & risers. Is it alot of water? How did you discover it? Was it winterized properly? Does it run good? Are you seeing any milkiness in your oil? Water in only one cylinder would make me think that either the block/head has a crack or possibly a blown head gasket between the cylinder and the water jacket. Before ya go tearing it down, I would wait for more input from some of the pro's.
TilliamWe
Banned
Originally posted by J.kopec:<br /> If you're sure it only has water in one cylinder, I would rule out the manifolds & risers. Is it alot of water? How did you discover it? Was it winterized properly? Does it run good? Are you seeing any milkiness in your oil? Water in only one cylinder would make me think that either the block/head has a crack or possibly a blown head gasket between the cylinder and the water jacket. Before ya go tearing it down, I would wait for more input from some of the pro's.
Kopec you may be exactly right but...<br /><br />I never rule out the exhaust manifolds or risers when a marine engine has water in a cylinder! :D <br />Plus they are the easiest thing to remove from the engine & have checked.
Haut Medoc
Tilliam wet,you are correct. However, I can't help but think that if it were a bad manifold/riser that water would be present in all cylinders on that side. His manifolds are new and his risers are two years old. I concede the fact that the only way to rule them out would be to pressure test them.
bobrock
im gonna pull the manifold and riser and bench test em next
bobrock
manifold pulled ... benchtested good ... next im pullin the head and lookin for a cracked block or a blown head gasket
bobrock
yep blown head gasket... runs better but who knows how long the cylinder will last
Haut Medoc
Glad it was nothing major! I guess you'll be out this weekend - Stripers still bitin'?
bobrock
yea the stripers are JUMPIN in the boat ...
