tranny cooler
loghomer
1976 Searay merc 255 hp TRS :( <br />replaced cooler and I still have fluid coming out of top of tranny dip stick with force!!!Any other ideas before I have a bon fire with this off shore bank account of mine
snapperbait
Re: tranny cooler
Short of a total teardown on the trans, I've got two thoughts before ya put fire to it..<br /><br />If you don't have a manual for the trans, although not specific for the TRS trans, this link might be of some help..<br /> http://mysite.verizon.net/vze6mxo8/downloads/Velvet_Drive_Serv_Manual.pdf <br /><br /><br />If the fluid's not milky... <br />#1, sticking pressure relief spring, or something else screwy going on with the control valve assembly allowing it to go over regulated pressure... Straight forward to dis-assemble an inspect..<br /><br />#2, there's a screen inside the bottom hose fitting on the trans.. It could be plugged with debris...<br /><br />If the fluid's still milky, I'm at a loss..
