GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
I need to repair the threads on one end of the pivot rod which the trim/tilt cylinders attach to. I screwed up the threads when I removed the rod, so now I can't start the nut. Anyone know a quick fix? Thanx.
you should be able to buy a thread file if its only a minor bugger (some have the pitch of the thread and some just have a single 60 deg)<br /><br />if its worse you would need a die the correct size <br /><br />
