replaced starter with no success
yesterday trouble shot and figured soleniod on starter was bad... replaced and tested at store.. now it sounds like it wants to work but makes clicking like poping noises... when key is turned... this may be my battery so i tied jump start with the same effect... im slightly stupid maybe i hooked wires up incorrectly... any idea where to get installation diagram...
tommays
Re: replaced starter with no success
its a hard to help because you not telling anybody what brand type and year you have<br /><br />tommays
jeff13601
Did you put the positive and negative cables on the battery correctly? Do what Tommays asked and give more info..
Reel Poor
Went back and read your other article.<br /><br />Did you replace the solenoid....Or did you replace the complete starter and solenoid assembly?<br /><br />If you only replaced the solenoid, go back and get the starter also.<br /><br />From your previous post I would bet your starter was the problem that burned the solenoid out.<br /><br />Some reasons for multiple starter failure; <br />1..miss alignment of starter and flywheel<br />2..oil or water saturation<br />3..low voltage to starter ie; battery, cables, connections<br />4..long cranking periods ie; hard to start<br />5..Autozone quality starters
Don S
From your other post you described a clicking from the part that has a wire going to the center of the distributor. I posted a picture and you confirmed that was what was clicking. However that is a coil and has absolutly nothing to do with the starting system. Of course there is a start slave solenoid next to it that is probably your problem.<br />Next time it clicks, check to see that there is power to the big yellow/red wire on the solenoid.<br /><br />
wake5150
Don,<br /> Where do you get these great diagrams? Do real Mercruiser Techs have electronic copies of the manuals?<br /><br />Wake
jeff13601
Im hoping that Don has all of these saved on floppy discs. They have saved a lot of people
Don S
All it takes is to scan an image from a manual and use a program like "Paint" on your computer to put in the words and pointers. All the red I added to a picture from a service manual. <br />Yes, Mercruiser dealers do have access to some of the manuals (But not ALL). And don't ask, they are not emailable and I wouldn't abuse the pivilege by sharing it without permission from Mercruiser anyway.
