TJOSEPH869
- Joined
- May 10, 2005
- 9
OK, FIRST QUESTION I HAVE FOR YOU GUYS. MAXUM 1988 MERCRUISER 3.0 LITRE i/o ALPHA 1 OUTDRIVE, I RECENTLY PULLED IT OUT OF THE WATER AND ONE OF THE FIRST THINGS I SAW THAT WAS DISTURBING WAS A LOOSE WIRE HANGING OFF THE TOP OF THE OUT DRIVEFROM SOME CIRCULAR METAL CAP. THER IS AN IDENTICAL WIRE ACROSS FROM IT THAT IS ATTACHED TO A CIRCULAR METAL CAP ON THE TOP OF THE DRIVE AND GOES INSIDE THE BOAT AND INTO THE HYDRAULIC WIRING. WHAT IS THE PURPOSE OF THE WIRE AND CAN I RE-ATTACH IT BUY GOING THROUGHT THE WALL OF THE BOAT WITH A PIECE OF WIRE AND RECONNECTING? <br />PROBLEM 2: THERE IS A LEAK IN THE HOSE THAT GOES FROM THE HYDRAULIC PUMP TO THE TRANSOM AND TO THE PISTION. THE CONNECTION IS UNREACHABLE FROM THE INSIDE, ITS ALL THE WAY UNDERNEATHE THE BACK OF THE MOTOR. IS IT A BAD IDEA TO CUT THE AREA OF THE HOSE THAT IS LEAKING OUT AND REPLACE IT WITH BACK TO BACK HOSE BARBS AND A NEW PIECE OF HOSE? OTHERWISE HOW CAN I ACESS THE CONNECTION?<br /><br />THANKS IN ADVANCE.<br />JOE NY
